Previous Topic: Accountability for EntriesNext Topic: ABEND—Terminate Server
Specific Control Options
This content provides the format, defaults, entry methods, and descriptions of the CA Top Secret control options.
This section contains the following topics:
ADABAS—ControlsSVC Numbers
ADMINBY—Record Administration Information
ADSP—Security Indicator
AUDFIL2—Identify the Alternate Audit/Tracking File
AUDFILE—Identify the Audit/Tracking File
AUDIT(SWITCH)—Switch to Alternate Audit Tracking File
AUDIT—Restart Audit Task
AUTH—Merge Records for Search
AUTOEDSN—Edit AUTOERASE Data
AUTOERASE—Control Automatic Data Erase
BACKUP—Backup the Security File
BATCHCAN—Cancel Batch Job
BKPFILE—Identify Backup File
BYPASS—Bypass Resource Checking
CACHE—Reserve Memory
CANCEL—Allow Operating System CANCEL
CCIVM—Identify Virtual Machine for CAICC
CHOWNURS—Allow CHOWN Command
CMDNUM—Number of Command Processors
CPF—Activate Command Propagation Facility at Startup
CPFFILE—Identify CPF Recovery File
CPFLOCAL—Identify CPF Node Name
CPFNODE—CPF Node Changes
CPFNODES—Identify Remote Nodes for CPF
CPFOUT—Identify Virtual Machine for CPF Journal Files
CPFRCVUND—Receive Commands from Undefined Nodes
CPFSTATUS—Display Status of CPF Options
CPFTARGET—TARGET Keyword Default
CPFTRACE—Debugging Tool
CPFWAIT—WAIT Keyword Default
CUSTKEY—Define a Key for Security File Encryption
DATE—Date Format
DB2FAC—Group and Protect DB2 Subsystems
DEBUG—Produce Dumps
DFLTRNGG—GID Default Range
DFLTRNGU—UID Default Range
DIAGTRAP—Produce Diagnostic Dump
DISPMASK—Display Attribute of MASK
DL1B—PSB and DBD Security
DOWN—Inactive Characteristics
DRC—Detailed Error Reason Code Characteristics
DUFPGM—Program to Use INSTDATA
DUMP—Dump Control Blocks
ETRLOG—Send Security Events
ETROPTS—Events Sent
EXIT—Installation Exit
EXPDAYS—Security File Expiration Interval
FACILITY—System Facility Processing
GOSETGID—SAF Callable Service
HFSACL—HFS File System
HFSSEC—HFS Security On or Off
HPBPW—Expired Password for Batch Job
IMS—Control IMS Security Processing
INACTIVE—Deny Use of Unused ACIDs
INSTDATA—Global Installation Area
IOTRACE—Trace Activity
JCT—JES2 JCT Offsets
JES—JES Subsystem Information
JESNODE—JES Local Node Name
JOBACID—Identify the Field from Which to Derive the ACID
KERBLVL—Highest Kerberos Encryption Level Available
LDAPNODE—LDAP Node
LDS—LDAP Outbound Processing
LDSRETRY—LDS Server Retry Count
LDSTIMEOUT—LDS Server Timeout
LDSTRACE—Control LDS Tracing
LMPCHECK—Verify LMP Key
LOG—Events to be Logged
LUUPDONCE—Force Statistics Update
MLACTIVE—Multilevel Security Checking
MLFSOBJ—UNIX Labels
MLIPCOBJ—UNIX IPC Labels
MLMODE—Multilevel Security Mode
MLNAME—Name Display
MLSECAUD—Multilevel Seclabel Auditing
MLWRITE—Data Write
MODE—Security Mode
MSG—Messages
MSUSPEND—MSCA ACID Protection
NEWPHRASE—Password Phrase Rules
NEWPW—Password Alterations
NJEUSR—NJE Store and Forward Nodes ACID
NPPTHRESH—Maximum Password Phrase Attempts
NPWRTHRESH—New Password Reverification Threshold
OMVSGRP—OMVSGRP Segment
OMVSTABS—UID and GID Tables
OMVSUSR—OMVS Segment for Extract
OPTIONS—Replace Old APARs
OPTIONS (z/VM)—Replace Fixes from Prior Product Releases
PASSCHAR—Password Valid Characters
PDSPROT—Protected PDSs
PER—Event Recording
POSIXMGRP—Enable OpenEdition
PPEXP—Days Before Password Phrase Expires
PPHIST—Number of Password Phrases Recorded
PPHRASE—Allow Password Phrases for z/VM
PPSCHAR—Special Characters in Password Phrases
PRODUCTS—Special Products
PROFINTERVAL—Profile Non-refreshable Period
PTHRESH—Password Violation Threshold
PTKRESCK—Pass Ticket Authorization
PWEXP—Password Expiration Interval
PWHIST—Number of Previous Passwords Retained
PWVERIFY—Force Password Verification
PWVIEW—(Obsolete)
RCACHE—Cache Hardening
RCQNAME—Caches Hardening Selection
RDT2BYTE—(Obsolete)
RECFILE—Identify Recovery File
RECOVER—Record Changes in Recovery File
REFRESH—Reinitialize CA—CAF Modules into CSA
REINIT—Control Blocks and Modules
RESETEOD—Restart After Z Stop
RESETSTATS—Reset Stats Counters
RPW—Restricted Password List
SECCACHE—Security Record Cache
SECFILE—Security File Name
SECTRACE—Security Trace
SHRFILE—Share Files
SHRPROF—Shared Profile Table
SHUTDOWN—Shutdown Server
SMA—Start SMA Dynamically
SMFTYPE—Change SMF Record Type
ST—Control Option Display
STATG
STATGINT
STATREC—Statistics Processed
STATS—Display Statistics
STATSLOG—Statistics Dataset Name
STATUS—Display Control Option Settings
SUBACID—Batch Job ACIDs
SVCDUMP—System Dump
SWAP—Program Shopping
SYNCH—Synchronize Tables
SYSOUT—Diagnostic Log
SYSPLEX—XES and XCF Availability
TAPE—Tape Protection
TEMPDS—Protect Temporary Data Sets
TEXTTSS—Report and Message Text
TIMELOCK—Lock Interval
TIMER—AUDIT/TRACKING File Write Interval
TNGMON—Error Messages
TSS—Console Prompts
TSSCMDOPT—z/VM Command Defaults
TSSCMDOPTION—Command Defaults
UNIXOPTS—Special Options for USS
UPCASE—Upper Case Messages
VERSION—Version Display
VMDEBUG—Internal Debugging
VMDUMP—Dump
VMFAC—Group z/VM Systems
VMLOGID—Message Identifier
VMTRACE—Specify Trace Data
VSAMCAT—Catalog Volume Check
VTHRESH—Access Violation Response
XCF(*)—Information to Remote Systems
