Previous Topic: MODE—Security ModeNext Topic: MSUSPEND—MSCA ACID Protection
MSG—Messages
Valid on z/OS and z/VM.
Use the MSG control option to modify the characteristics of certain CA Top Secret violation messages that are contained in the CA Top Secret Message Table. You can alter the characteristics of the message, such as when and how the message is issued or suppressed, but not the text of the message.
MSG control option considerations:
All entry methods are accepted.
MSG(nnnn,option,option,...)
MSG(nnnn)
nnnn
The four‑digit CA Top Secret message number that corresponds to the message being listed or modified.
SEC9
Indicates that the message is a violation summary that is sent to the security console by using WTO route code 9.
NOSEC9
Cancels the SEC9 suboption.
USER
Indicates that the message is directed to the user.
NOUSER
Cancels the USER suboption.
FORCE
Message must always be issued, even if the LOG option does not include the MSG suboption.
NOFORCE
Cancels the FORCE suboption.
DSNAME
Message is associated with data set name indicator message TSS7230I.
NODSN
Cancels the DSNAME suboption.
SWARN
Suppress message display if user is in WARN mode.
NOSWARN
Cancels the SWARN suboption.
SIMPL
Suppress the message display if user is in the IMPL mode.
NOSIMPL
Cancels the SIMPL suboption.
SDEF
Suppress the message display for defined users.
NOSDEF
Cancels the SDEF suboption.
SUNDEF
Suppress the message display for undefined users.
NOSUNDEF
Cancels the SUNDEF suboption.
SBATCH
Suppress message display if user is using BATCH processing.
NOSBATCH
Cancels the SBATCH suboption.
STSO
Suppress the message display if user is on TSO.
NOSTSO
Cancels the STSO suboption.
SONLINE
Suppress the message display for online users (CICS, IMS, and so on).
NOSONLINE
Cancels the SONLINE suboption.
SUPPRESS
Suppress the message display at all times for all users.
NOSUPPRESS
Cancels the SUPPRESS suboption.
Examples: MSG control option
This example displays the characteristics of a specific MSG or MSGs:
F TSS,MSG(nnnn)
This example indicates that message TSS7205 is suppressed for undefined batch jobs in the IMPL mode only:
F TSS,MSG(7205,SBATCH,SUNDEF,SIMPL)
This example determines the characteristics of message TSS7003W:
F TSS,MSG(7003)
This example goes in the Parameter File:
* CONTROL OPTIONS
MODE(WARN)
MSG(7003,SBATCH,SUNDEF,SIMPL)
