Valid on z/OS.
Use the REFRESH control option to request that CA Top Secret reinitialize all CA‑SAF modules from the system linklist into CSA. This control option should be used only under the direction of CA Top Secret Technical Support. The command should normally be preceded by an LLA refresh.
The REFRESH control option is protected by the Operator Accountability feature (CONSOLE attribute). CA Top Secret prompts the person entering the command from the console for the proper ACID and password before processing the REFRESH request.
REFRESH(SAF|modabbrv)
REFRESH without operands performs the same function as SAF.
Refresh all SAF modules from LINKLIST into CSA.
Refresh an individual SAF load module from LINKLIST into CSA. The module abbreviation (modabbrv) omits the prefix “SAF” from the actual load module name.
This example reloads module SAFOEDRV from linklist into CSA, deleting the existing copy:
TSS MODIFY(REFRESH(OEDRV))
This example refreshes the SAFOEDRV module:
F TSS,REFRESH(OEDRV)
