Valid on z/OS and z/VM.
Use the PPSCHAR control option to add, replace, or remove characters from the password phrase valid character list.
The list can:
Valid special characters are:
TSS MODIFY PPSCHAR(c,c,c,c,...)
To reset the control option, use the following command:
TSS MODIFY PPSCHAR()
This example uses character format to set the special characters to *, &, and %:
TSS MODIFY PPSCHAR(*,&,%)
This example uses hexadecimal format to set the special characters to &, _, and %.
TSS MODIFY PPSCHAR(50,60,6C)
This example resets the PPSCHAR control option
TSS MODIIFY PPSCHAR()
