Valid on z/VM.
Use the BKPFILE control option to identify the OS data set name containing the Backup File. Use the data set must reside on the DASD volume or minidisk at virtual address X'500' of the server machine.
This control option uses the Parameter File entry method.
BKPFILE(dataset‑name)
The OS data set name for the Backup File.
Default: The data set name created by the TSSMAINT utility (CAI.TOP.SECRET.BACKUP.FILE).
This example indicates that the OS data set name for the Backup File is SYS2.TOP.SECRET.BACKUP.FILE:
BKPFILE(SYS2.TOP.SECRET.BACKUP.FILE)
