Valid on z/OS.
Use the CMDNUM control option to determine the number of command processors initiated at startup of the CA Top Secret address space.
This control option uses the parameter file entry method.
CMDNUM(nn)
Specifies the number of command processors that CA Top Secret initiates at startup.
Range: 2 to 10
Default: 2
If TSS MODIFY STATUS is issued, no messages display. If TSS MODIFY is issued, messages showing the workload balance appear in the output. After changing TSS MODIFY STATUS to TSS MODIFY, the messages that show when CMDNUM(10) is set are:
TSS9610I ----- COMMAND PROCESSOR WORKLOAD BALANCE ----- TSS9611I total Commands Issued = 0000000004 TSS9612I Cmd 01 = 000.00% Cmd 02 = 098.94% TSS9612I Cmd 03 = 001.05% Cmd 04 = 000.00% TSS9612I Cmd 05 = 000.00% Cmd 06 = 000.00% TSS9612I Cmd 07 = 000.00% Cmd 08 = 000.00% TSS9612I Cmd 09 = 000.00% Cmd 10 = 000.00%
Although two is the minimum number of command processors, with the NT workstation and the higher number of commands being issued it might be necessary to start more processors.
When CMDNUM is set to three or higher, the first three processors are set up the following way:
This example indicates that five command processors are initiated at startup.
CMDNUM(5)
