Valid on z/VM.
Use the VMLOGID control option indicates the four character identifier or global identifier used in Last‑Used Messages as well as violation logging.
This control option uses the Parameter File entry method.
VMLOGID([sysid=]cccc)
Represents the name assigned to particular VM system. If the sysid is unknown it can be determined by typing in CP QUERY USERID. Use the response shows “userid AT sysid”.
Default: The last 4 characters of the sysid.
Use the four character identifier used in Last‑Used Messages and violation reports.
Note: If the sysid is omitted, VMLOGID is assumed to mean the VM system on which the server machine has started.
