Previous Topic: HPBPW—Expired Password for Batch JobNext Topic: INACTIVE—Deny Use of Unused ACIDs
IMS—Control IMS Security Processing
Valid on z/OS.
Use the IMS control option to set six different suboptions for IMS security processing.
All entry methods are accepted.
IMS([NO] {IMS61SUB} )
    [NO] {IMSATSDF}
    [NO] {IMSATSLG}
    [NO] {IMSDBDVL}
    [NO] {IMSLCFMG}
    [NO] {IMSPSBVL}
IMS61SUB
Specifies that the LU6.1 subpool name be used for the Automatic Terminal Signon (ATS) connection. The NO prefix disables this suboption and the LUNAME is used for the connection.
Default: NOIMS61SUB
IMSATSDF
Specifies that the facility DEFACID be used for the Automatic Terminal Signon. The NO prefix disables this suboption.
Default: NOIMSATSLG
IMSATSLG
Specifies that ATS signons are logged. The NO prefix disables this suboption.
Default: IMSDBDVL
IMSDBDVL
Specifies that DBD validation is performed in IMS; the default. The NO prefix stops DBD validation.
Default: IMSNOIMSATSDF
IMSLCFMG
Specifies that IMS transaction warning messages are displayed; the default. The NO prefix disables IMS warning messages.
Default: LCFMG
IMSPSBVL
Specifies that PSB validation will occur in IMS; the default. The NO prefix stops PSB validation.
Default: IMSPSBVL
Be aware of the following when using the IMS control option.
Examples: IMS control option
This example turns off PSB validation.
TSS MODIFY(IMS(NOIMSPSBVL))
This example allows the LU6.1 subpool name to be used for the ATC connection.
TSS MODIFY(IMS(IMS61SUB))
