Previous Topic: CPFTARGET—TARGET Keyword DefaultNext Topic: CPFWAIT—WAIT Keyword Default
CPFTRACE—Debugging Tool
Valid on z/VM.
Use the CPFTRACE control option as a debugging tool. CPFTRACE allocates an internal CPF trace table and should be used only at the request of CA Technical Support.
This control option uses the Parameter File and MODIFY entry methods.
CPFTRACE(ON|OFF)
ON
Specifies that the trace will be activated.
OFF
(Default) Specifies that the trace is inactive or has been deactivated.
