Previous Topic: UPCASE—Upper Case MessagesNext Topic: VMDEBUG—Internal Debugging
VERSION—Version Display
Valid on z/OS and z/VM.
Use the VERSION control option to display the version of CA Top Secret.
This control option uses z/OS and TSS MODIFY commands the entry methods.
VERSION
Example: VERSION control option
This example produces a version message:
TSS VERSION
In z/OS the result is:
TSS9660I VERSION= r.r rrSPxxAKOnn
rr
Specifies the release.
SPxx
Specifies the service pack level.
AKO
Specifies the Product Code.
nn
Specifies the version.
In z/VM the result is:
TSS0029I Version=12.0 SP0 Generated on 12/03/07 at 12:50:39 IPL: 0100
TSS0028I CP Version=12.0 SP0 Generated on 04/29/08 at 11:11:19
