Valid on z/VM.
Use the PER control option at the request of CA Technical Support to establish a Program Event Recording trap within the CA Top Secret VM server for debugging purposes.
Use the operands to the PER control option describe a complex event, or set of conditions, upon which a full server storage dump will be taken without restarting the server. Use the exact This control option has the following format: of the arguments will vary depending on the event being monitored and the type of trap required. Use these will be supplied by CA Technical Support personnel when required.
Use the PER control option is protected by the operator accountability feature. CA Top Secret prompts the person entering the command for the proper ACID/password combination before processing the option. CA Top Secret also creates an audit trail identifying the ACID under which the PER specification was made.
This control option uses the Parameter File and MODIFY entry methods.
PER(CAN|[condition‑list])
(Default) Cancels any previously established PER conditions. Note that this is done implicitly if a PER event occurs and a dump is taken; it is only necessary to specify CAN if the event does not occur and you no longer wish the trap to be in effect.
Sets of conditions describing the PER event to be trapped. Supplied by CA Technical Support.
