Previous Topic: PER—Event RecordingNext Topic: PPEXP—Days Before Password Phrase Expires
POSIXMGRP—Enable OpenEdition
Valid on z/VM.
Use the POSIXMGRP control option to enable OpenEdition VM external security and sets the maximum number of supplemental groups supported per user.
Modification of the control option requires a re‑IPL of the CP system.
This control option uses the Parameter File entry method.
POSIXMGRP(nnn)
Nnn
The number of groups that a user can have in his supplemental list.
If you specify 0, external security for OE/VM is disabled. Directory security will be used and not CA Top Secret.
Range: 32 to 125
Default: 0
Example: POSIXMGRP Control Option
This example sets 35 supplemental groups supported per user:
TSS MODIFY(POSIXMGRP(35))
