Valid on z/OS.
Use the ADABAS control option to control SVC numbers used by ADABAS at startup.
This control option uses the parameter file entry method.
Note: Valid for ADABAS 4.8 and 4.9 only. For information on the Software AG provided security interface for ADABAS r5.0 and above, contact Software AG.
ADABAS(nn1,nn2,nn3,nn4)
The SVC numbers (in decimal) that can be specified.
Range: Up to 4
This example indicates that SVCs 221 and 222 are used by ADABAS at startup:
ADABAS(221,222)
