Valid on z/OS and z/VM.
Use the MSUSPEND control option to allow the MSCA's ACID to be suspended automatically if the password violation threshold set via the PTHRESH option is exceeded. This prevents a user from making an unlimited number of guess attempts to determine the MSCA's password.
This option is ignored for BATCH or STC use.
All entry methods are accepted.
MSUSPEND(YES|NO)
MSCA's ACID is suspended if the password violation threshold is exceeded.
(Default) Cancels the MSUSPEND option.
If a suspended MSCA signs on and enters the password correctly, CA Top Secret prompts the master console via message:
This example protects the MSCA's password from password‑guessing attempts:
F TSS,MSUSPEND(YES)
