Previous Topic: RDT2BYTE—(Obsolete)Next Topic: RECOVER—Record Changes in Recovery File
RECFILE—Identify Recovery File
Valid on z/VM.
Use the RECFILE control option to identify the OS data set name of the Recovery File. Use the data set must reside on the DASD volume or minidisk at virtual address X'400' of the server machine.
This control option uses the Parameter File entry method.
RECFILE(dataset‑name)
datasetname
The OS data set name for the Recovery File.
Default: The OS data set name created by the utility TSSMAINT (CAI.TOP.SECRET.RECOVERY.FILE).
Example: RECFILE Control Option
This example indicates that the virtual address of the data set name for the Recovery File is SYS2.TOP.SECRET.RECOVERY.FILE:
RECFILE(SYS2.TOP.SECRET.RECOVERY.FILE)
