Valid on z/VM.
Use the AUDIT(SWITCH) option to force a switch to the alternate Audit Tracking File if multiple files are being used. If only one ATF is being used it forces a wrap to the top of the file.
All entry methods are accepted.
TSS MODIFY AUDIT(SWITCH)
This example wraps to the top of the alternate ATF when the primary ATF is full:
