Previous Topic: BKPFILE—Identify Backup FileNext Topic: CACHE—Reserve Memory
BYPASS—Bypass Resource Checking
Valid on z/OS and z/VM.
Use the BYPASS control option to allow the MSCA to request emergency bypassing of resource checking for a specific ACID. Administrators must be given MISC9(BYPASS) authority to use this control option.
Note the following additional rules for use:
This control option uses the MODIFY entry method.
BYPASS(userid(1)[,userid(2),...userid(10)][ALL][RESET]
userid(n)
Represents the virtual machine userid for which security is to be bypassed.
ALL
Allows all virtual machines to bypass security.
Important! Use with extreme caution.
RESET
Terminates security bypass for all users that were specified to bypass security.
Examples: BYPASS Control Option
This example causes the virtual machine USER01 to bypass all resource security checking:
TSS MODIFY('BYPASS(USER01)')
This example terminates security bypass for USER01, and any other ACID that was specified to bypass security:
TSS MODIFY('BYPASS(RESET)')
