Valid on z/OS.
Use the TSSCMDOPTION control option to allow users to establish default settings for TSS command specific options. The options can be in any order, however the right most takes precedence.
All entry methods are accepted.
TSSCMDOPTION (option1,option2,…)
The following options are available:
When enabled, CA Top Secret records and lists information in ACID security records to indicate the:
ADMINBY data is stored each time an ACID is created, a FACILITY is added, or a resource is permitted.
When ADMINBY is turned on:
(Default) Suppresses the administrative date—time stamp storage and LIST display.
(Default) Displays all the related hierarchy ACIDs information beyond the owning ACIDs And the full NAME attributes.
Does not display the ADMINBY information, ACID hierarchy information beyond the owning ACID, or the full NAME attribute. This saves significant overhead in security file access and in CPU time expended.
Displays all information included in VERBOSE plus:
