Previous Topic: SYSPLEX—XES and XCF AvailabilityNext Topic: TEMPDS—Protect Temporary Data Sets
TAPE—Tape Protection
Valid on z/OS.
Use the TAPE control option to specify the type of tape protection (if any) in effect at the installation.
TAPE(OFF|DSNAME|DEF)
OFF
(Default) z/OS will not invoke CA Top Secret to validate a tape access request. TAPE(OFF) is used to indicate the use of external tape management packages such as TMS or TLMS.
DEF
CA Top Secret will validate access requests for defined volumes only.
DSNAME
CA Top Secret will perform data set name checking using the full data set name supplied on the DSNAME keyword of the JCL. If CA Top Secret cannot determine what the DSNAME is, such as when creating an NL tape from an SL tape, CA Top Secret supplies a data set name of:
$$.UNKNOWN.TAPE.DSN
If you encounter this problem, you will need to add a PERMIT for this data set name as follows:
TSS PERMIT(ALL) DSNAME($$.UNKNOWN.TAPE.DSN)
                ACCESS(ALL)
Appropriate Settings for TAPE Option
See the User Guide for detailed descriptions of volume security and tape data set security.
Examples: TAPE control option
Enter:
To:
TAPE(DEF)
Protect defined volumes only
TAPE(DSN)
Use CA Top Secret to protect tape data sets
TAPE(OFF)
To indicate the use of a TLMS or TMS interface
TAPE(DSN)
To use CA‑Tape
