Valid on z/OS.
Use the OMVSUSR control option to specify the ACID used to provide the OMVS segment for an extract for any user who does not have an OMVS segment.
Note: LNXENTS should be added to the ACID specified in the OMVSUSR control option using the ALL facility. This LNXENTS entry will act as a default for any users who do not have a LNXENTS specified on their acid. For information, see the Command Functions Guide.
All entry methods are accepted.
OMVSUSR(acid)
The ACID should be given the fields UID, HOME, and OMVSPGM. This acid might also be given DFLTGRP to provide a default for the OMVSGRP control option.
