Previous Topic: VTHRESH—Access Violation Response
XCF(*)—Information to Remote Systems
Valid on z/OS.
Use the XCF(*) control option as the CA Top Secret “send” command to route information to all remote systems in the sysplex.
Note the following:
This control option uses the MODIFY commands entry method.
XCF(*)
Example: XCF(*) control option
This example updates the violation threshold on all systems in a group on a sysplex with the VTHRESH control option.
TSS MODIFY('VTHRESH (10,NOT), XCF(*)')
