Previous Topic: AUDFIL2—Identify the Alternate Audit/Tracking FileNext Topic: AUDIT(SWITCH)—Switch to Alternate Audit Tracking File
AUDFILE—Identify the Audit/Tracking File
Valid on z/VM.
Use the AUDFILE control option to identify the OS data set name containing the Audit/Tracking File. Use the data set must reside on the DASD volume or minidisk at virtual address X'300' of the server machine.
This control option uses the Parameter File entry method.
AUDFILE(dataset‑name)
dataset‑name
The OS data set name of the Audit/Tracking File.
Default: CAI.TOP.SECRET.AUDIT.FILE.
Example: AUDFILE Control Option
This example indicates that the data set name for the Audit/Tracking File is SYS2.TOP.SECRET.AUDIT.FILE:
AUDFILE(SYS2.TOP.SECRET.AUDIT.FILE)
