Previous Topic: EXPDAYS—Security File Expiration IntervalNext Topic: Universal Suboptions
FACILITY—System Facility Processing
Valid on z/OS and z/VM.
Use the FACILITY control option to:
All entry methods are accepted.
FACILITY(facility|ALL)
FACILITY(facility=subopt1<=value1>,...)
facility
The full name of a single facility.
You can specify the following items as part of your FACILITY control option entry:
Example: Display the Status of the TSO Facility
This example displays the status of the TSO facility:
F TSS,FACILITY(TSO)
Example: Update the FACILITY Option
This example updates the FACILITY option:
TSS MODIFY(FACILITY(subopt1=operand<=value><,subopt2<=value2>>…))
Example: Alter the BATCH Facility to WARN Mode and Set NOLUMSG
This example alters the BATCH facility to WARN mode and sets NOLUMSG.
Note: The suboption MODE requires a value, but that the NOLUMSG suboption does not.
TSS MODIFY('FACILITY(BATCH=MODE=WARN,NOLUMSG)')
