Previous Topic: MLFSOBJ—UNIX LabelsNext Topic: MLMODE—Multilevel Security Mode
MLIPCOBJ—UNIX IPC Labels
Valid on z/OS.
Use the MLIPCOBJ control option to specify whether UNIX IPC objects are required to have security labels.
All entry methods are accepted.
MLIPCOBJ(YES|NO)
YES
UNIX IPC objects must have security labels.
NO
(Default) Security labels are not required for UNIX IPC objects.
Example: MLIPCOBJ control option
This example specifies that security labels are required for UNIX IPC objects:
F TSS,MLIPCOBJ(YES)
