Previous Topic: ETRLOG—Send Security EventsNext Topic: EXIT—Installation Exit
ETROPTS—Events Sent
Valid on z/OS.
Use ETROPTS to control which events the Monitor sends to the CA-Examine product.
All entry methods are accepted.
ETROPTS(ADD|REM,VIO,LOG,START,INIT,USS,CMDADM,CONTROL)
ADD
Indicates that a new category of events are added to the current list of events.
REM
Indicates that a category of events are removed from the current list.
VIO
Transmits security violation events to CA-Examine. This includes initiations and resource access violations.
LOG
Sends Audited events to CA-Examine.
Examples: ETROPTS control option
This example adds successful initiations/terminations and administrative commands to the current list of events sent to CA-Examine:
F TSS,ETROPTS(ADD,INIT,CMDAMD)
This example specifies that the R_chown and R_chmod USS calls are sent to CA-Examine:
TSS MODIFY(ETROPTS(ADD,USS(CHOWN,CHMOD)))
