Previous Topic: DL1B—PSB and DBD SecurityNext Topic: DRC—Detailed Error Reason Code Characteristics
DOWN—Inactive Characteristics
Valid on z/OS and z/VM.
Use the DOWN control option to determine how jobs are initiated and passwords changed when the CA Top Secret address space is inactive. This control option must be set while CA Top Secret is active.
All entry methods are accepted.
DOWN(facility,action,facility,action,…facility,action)
facility
Identifies the system facility being affected by the DOWN action. Valid values are:
action
Identifies the action that CA Top Secret performs when its address space is DOWN. Valid values are:
The default is DOWN(BW,SB,TW,OW).
The DOWN options are ignored if CA Top Secret is processing in global DORMANT mode.
This table shows how DOWN actions will affect various CA Top Secret processes.
PROCESS
WAIT
BYPASS
FAIL
NORMAL
Initiation or Logon
Initiations held and terminals locked
Security Ignored
Initiation Terminated
TSO UADS Password Required
Request for Password change
Wait
Wait
Wait
TSS command
Failed
Failed
Failed
Failed
Data set in FAIL mode
Failed
BYPASS
Failed
Failed
Submit a permitted ACID
Job submitted without password
TAPE(DEF) processing (volume level)
Volume access denied
BYPASS
Examples: DOWN control option
This example shows how the default DOWN(BW,SB,TW,OW) forces CA Top Secret to process security when its address space is down.
BW
Batch jobs and password changes (B) will wait for CA Top Secret to be reactivated (W).
SB
STC initiations (S) will bypass security checking (B).
TW
TSO logons and password changes (T) will wait for CA Top Secret to be reactivated (W).
OW
Online initiations and password changes (O) will wait for CA Top Secret to be reactivated (W).
Note: An action of B normally indicates to bypass all security. However, a TSO logon with a DOWN option of TB in effect will result in the UADS password for the user being checked.
