Previous Topic: LDS—LDAP Outbound ProcessingNext Topic: LDSTIMEOUT—LDS Server Timeout
LDSRETRY—LDS Server Retry Count
Valid on z/OS.
Use the LDSRETRY control option to set the retry count for the LDS server.
The LDS server task propagates eligible TSS commands to remote LDAP directories defined through NDT LDAPNODE records. The LDS server sends each command to the remote directory and waits for acknowledgment before sending out the next command. The LDSRETRY count controls the number of times a failed send operation will be retried, before the LDAPNODE is deactivated and further send operations are stopped.
All entry methods are accepted.
LDSRETRY(nnn)
nnn
Specifies the number of times the LDS server task will retry a failed send operation to the remote LDAP directory, before deactivating the LDAP node.
Default: 3
Example: LDSRETRY control option
This example uses the LDSRETRY control option to dynamically enabled an CA Top Secret system:
F TSS,LDSRETRY(nnn)
