Previous Topic: DOWN—Inactive CharacteristicsNext Topic: DUFPGM—Program to Use INSTDATA
DRC—Detailed Error Reason Code Characteristics
Valid on z/OS and z/VM.
Use the DRC control option to modify the characteristics of Detailed Error Reason Codes (DRCs).
This control option uses the Parameter file, z/OS and TSS MODIFY commands entry methods.
DRC(nnn,option,option...)
nnn
A three‑digit decimal number which represents the DRC being modified or listed. Hexadecimal equivalents appear in many messages and on violation reports in TSSUTIL. Do not use these equivalents.
Range: 001 to 159
AUDIT
Violation event is tagged with an audit attribute to allow TSSUTIL to select it with EVENT(AUDIT) as well as normal EVENT(VIOL).
NOAUDIT
Resets the AUDIT suboption.
FAIL
Violation causes CA Top Secret to terminate the access attempt in ALL modes.
NOFAIL
Resets the FAIL suboption.
FAILWARN
Violation causes CA Top Secret to terminate access attempts in WARN as well as FAIL or IMPL modes.
NOFAILWARN
Resets the FAILWARN option.
PW
Indicates that the violation is a password type violation, such as an invalid password entry, as opposed to an access violation such as an unauthorized resource access attempt.
NOPW
Resets the PW suboption.
NOVIOL
Do not treat event as a violation. Instead, flag the event, but do not FAIL the user.
VIOL
Resets the NOVIOL suboption.
Additional violation control can be performed in the installation exit via the VIOLATION call.
Examples: DRC control option
This example indicates that DRC 002: “Initiation failed by site exit” will terminate access attempts in all modes, including both DORMANT and WARN modes. CA Top Secret will also write an Audit Record for this type of violation:
DRC(002,FAIL,AUDIT)
This example displays the characteristics of DRC 002 as an z/OS Modify command:
F TSS,DRC(002)
