Valid on z/VM.
Use the BATCHCAN control option to allow the CA Top Secret administrator s to cancel batch jobs while they are running prior to completion.
This control option uses the MODIFY entry method.
BATCHCAN(nnnn)
Indicates the four-digit job number identified on the batch line of the output of a TSS MODIFY(STATUS) command. Use the job number shows in that display as J=nnnn.
This example stops batch job 1234 before it has finished running:
BATCHCAN(1234)
