Valid on z/VM.
Use the CCIVM control option to identify the virtual machine that will run CAICCI, the Common Communications Interface component of CA Common Infrastructure Services. CPF uses CAICCI for communication requirements between nodes.
This control option uses the Parameter File entry method.
CCIVM(userid)
The userid of the virtual machine that will run the CAICCI component of CA Common Infrastructure Services.
Default: CCIVM
