Valid on z/OS.
Use the TNGMON control option to set and activate error messages sent to a Unicenter console.
You can identify one or many Windows NT machines as CA Common Services monitors. However, you can also identify other CA Common Services monitors from within CA Common Services.
Considerations:
All entry methods are accepted.
TNGMON(ON|OFF) (ADDTO|REMOVE, ip address[,DEBUG])
Enables the TNG monitor to send error messages to a Unicenter console. If the monitor is on, and there are no TNG monitor table entries, the monitor does not process any data. The same is true if the table has entries but monitor is off.
Disables the TNG monitor from sending error messages to a Unicenter console.
Indicates that a new IP address is added to the TNG monitor table.
CA Top Secret will not allow duplicate entries to the TNG monitor table. If an entry is added that already exists, CA Top Secret recognizes its existence and returns a MODIFY FUNCTION SUCCESSFUL.
Indicates that an IP address is removed from the TNG monitor table.
If you remove the last entry in the TNG monitor table, and the internally used entry count is set to zero, the TNG monitor is automatically placed in an off status.
Note: The REM function used with DEBUG only removes the DEBUG function, not the IP address.
Identifies the PC address for which CA Top Secret violations are sent.
