Valid on z/OS and z/VM.
Use the AUTH control option to indicate whether CA Top Secret:
All entry methods are accepted.
AUTH(OVERRIDE[,ALLOVER])
AUTH(MERGE,[ALLOVER|ALLMERGE])
(Default) Indicates that the User, Profile, and All records are searched separately in the following manner:
Note: OVERRIDE is mutually exclusive with MERGE and ALLMERGE. OVERRIDE implies ALLOVER.
CA Top Secret merges user and profile records, and searches this merged record for the requested authorization. The system will not make an access decision until it has searched the entire merged record.
(Default) Indicates that the ALL record should be searched if no authorization is found in the user or profile records.
Note: ALLOVER is mutually exclusive with ALLMERGE.
Indicates that the ALL record is merged with user and profile records. ALLMERGE implies MERGE.
