Previous Topic: NEWPW—Password AlterationsNext Topic: NPPTHRESH—Maximum Password Phrase Attempts
NJEUSR—NJE Store and Forward Nodes ACID
Valid on z/OS.
Use the NJEUSR control option to define a default ACID to be used for NJE Store‑and‑Forward nodes where no other userid can be identified. This control option is used to specify the userid when building a default token in response to a verify SESSION=TKNUNKWN request.
Notes:
This control option uses the Parameter File and TSS MODIFY Command entry methods.
NJEUSR(acidname)
acidname
The ACID that is used in the VERIFYX call.
Examples: NJEUSR control option
This example sets the NJEUSR ACID using the TSS MODIFY command:
TSS MODIFY(NJEUSR(acidname))
or
F TSS,NJEUSR(acidname)
This example deactivates the NJEUSR control option:
TSS MODIFY('NJEUSR( )')
Note: The new option displays as
TSS9661I CA Top Secret JES      Status
 JCT(INDEV=0328,ROUTE=0324,NJHDR=0000)
 JES(SSID=JES2,TYPE=JES2,LEVEL=OS 2.10,VERIFY)
 JESNODE(*NONE*)            NJEUSR(*NONE*)
 JOBACID(U,7,0)             SUBACID(U,7)
