Valid on z/OS and z/VM.
Use this control option to change the status and attributes of a CPF node after CA Top Secret has initialized and CPF is activated.
When a node is defined using the parmlib CPFNODE method rather than the NDT, the word STATIC appears in the display when a TSS MODI STATUS(CPF) command is issued. For example:
TSS966II CA Top Secret CPF Status ? CPFNODE(XE58) Static Status(ACTIVE,NOSPOOL,...)
This control option uses the z/OS and TSS MODIFY command entry methods.
CPFNODE(nodename=STOP|START|REFRESH)
Stop sending and receiving commands and passwords for the specified node. Currently queued messages are processed but no new messages are queued to this node.
While the specified node is stopped, entries for the node are not be written to the CPF Recovery File. Entries for the other CPF nodes continue to be written to the CPF Recovery File.
Activate a previously stopped node, or install and activate a new NDT defined node.
Modify the node attributes based on current NDT definitions. New attributes only affect commands and password changes not yet queued to the node. Recovery file records and in‑core queue entries are processed based on the attributes in effect prior to the refresh.
This example modifies the attributes of CPF node SYS2 using the z/OS Modify command:
F TSS,CPFNODE(SYS2=REFRESH)
This example uses the CPFNODE REFRESH option with the TSS MODIFY command:
TSS MODIFY(CPFNODE(SYS2=REFRESH))
