Valid on z/OS.
Use the AUTOEDSN control option to edit the data set selection list associated with AUTOERASE(YES). At most, 150 data sets or prefixes can be added to this list.
All entry methods are accepted.
AUTOEDSN((ADD|REM),(dataset.prefix|'exact.dataset.name'))
Adds an entry to the list.
Removes an entry from the list.
Any valid z/OS data set name enclosed by quotes. When AUTOERASE(YES) is set and a data set is SCRATCHed, if the exact entry on the AUTOEDSN table matches the data set name, DADSM is invoked to overwrite the DASD with nulls.
Range: Up to 44 characters
Any valid z/OS data set name not enclosed by quotes. When AUTOERASE(YES) is set, and a data set is SCRATCHed, if the entry on the AUTOEDSN table matches the initial segment of the data set name, DADSM is invoked to overwrite the DASD with nulls.
This example adds the exact name highlvl.sampdata to the autoerase table:
TSS MODIFY(AUTOEDSN(ADD,'highlvl.sampdata'))
This example adds prefix sampdata to the autoerase table as a prefix:
TSS MODIFY(AUTOEDSN(ADD,sampdata))
This example removes the exact name highlvl.sampdata from the autoerase table:
TSS MODIFY(AUTOEDSN(REM,'highlvl.sampdata'))
This example removes the prefix sampdata from the autoerase table:
TSS MODIFY(AUTOEDSN(REM,sampdata))
