Previous Topic: LDSTRACE—Control LDS TracingNext Topic: LOG—Events to be Logged
LMPCHECK—Verify LMP Key
Valid on z/OS and z/VM.
Use the LMPCHECK control option to verify that the correct License Management Program (LMP) encryption key is being used for this system.
Under normal processing, if a valid LMP key has not been found, CA Top Secret issues a warning message every 30 seconds until LMP verifies a valid key. For information, see the CA Common Services for z/OS documentation.
This control option uses the z/OS Start command and z/OS Modify commands entry methods.
LMPCHECK
