Valid on z/OS and z/VM.
Use the SYSOUT control option to spin off a CA Top Secret diagnostic log (DDNAME=$$LOG$$) and specifies the SYSOUT class and destination for the log.
Note: If this parameter is entered more than once in the Parameter File, the first entry is used.
All entry methods are accepted.
In z/OS, this control option has the following format:
SYSOUT(class,dest)
Identifies the JES SYSOUT class for diagnostic log output.
Indicates the destination of the diagnostic log output.
Default: SYSOUT(A,LOCAL).
In z/VM this control option has the format:
SYSOUT(userid)
Specifies the userid of the virtual machine to receive the console log and server dumps.
Default: SYSTEM
This example:
TSS MODIFY('SYSOUT(B,REMOTE1)')
