Valid on z/VM.
Use the AUDFIL2 control option to identify the OS data set name containing the alternate Audit/Tracking File. Use the data set must reside on the DASD volume or minidisk at virtual address X'301' of the server machine.
This control option uses the Parameter File entry method.
AUDFIL2(dataset‑name)
The OS data set name of the alternate Audit/Tracking File.
This example indicates that the data set name for the alternate Audit/Tracking File is SYS2.TOP.SECRET.AUDIT.FILE2:
AUDFILE(SYS2.TOP.SECRET.AUDIT.FILE2)
