Valid on z/OS nad z/VM.
Use the RPW control option to allow the site to modify and list the contents of the restricted password list. This allows the site to prevent the use of obvious passwords such as company names, titles, month and names. Mixed case passwords are temporarily transformed to uppercase before being checked against the RPW prefixes.
The supplied RPW is loaded initially at startup. It can be modified anytime afterward via the RPW control options. It is not rebuilt other than from REINIT of CA Top Secret.
All entry methods are accepted.
RPW(LIST)|(RESET)|(ADD,password,...)|(REMOVE,password,..)
Displays contents of restricted password list. This operand is not protected since it does not alter security.
Removes all password prefixes currently in the restricted password list, including the product defaults. Once the RPW (RESET) option clears all user and default password restrictions, the 33 default prefixes can only be recovered by manual RPW(ADD,…) or automatically by a REINIT of CA Top Secret.
Adds one or more password prefixes to the restricted password list.
One‑ to seven‑character password prefix.
Removes one or more password prefixes from restricted password list.
CA Top Secret provides a list of a maximum 511 password prefixes, which cannot be used as new passwords. Of the 511 password prefixes, 33 are default entries. This list is only in effect for NEW passwords that are entered while the NEWPW(RS) control option is in effect.
APPL APR ASDF AUG BASIC CADAM
DEC DEMO FEB FOCUS GAME IBM
JAN JUL JUN LOG MAR MAY
NET NEW NOV OCT PASS ROS
SEP SIGN SYS TEST TSO VALID
VTAM XXX 1234
The table provided by CA may contain up to 511 password prefixes (including the 33 default password prefixes). A site may specify as many RPW control option entries as required.
Use of the RPW control option is protected by the accountability feature. CA Top Secret prompts the person entering the command for the authorized ACID/password combination before processing the command.
This example indicates that CA Top Secret should not accept a set of new passwords if specified by users:
F TSS,RPW(ADD,STAFF1,BATMAN,MYPASSW,MGRPASS)
The passwords shown above will no longer be able to be specified as new passwords. Users who are currently using these passwords will function normally.
This example removes a password from the list:
F TSS,RPW(REMOVE,BATMAN)
BATMAN may now be selected as a new password.
This example determines the current contents of the restricted password list:
TSS MODIFY(RPW (LIST)) IBM TEST SYS LOG SIGN TSO PASS NEW VTAM NET APPL ROS BASIC FOCUS CADAM VALID DEMO GAME JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC XXX ASDF 1234 STAFF1 BATMAN MYPASSW MGRPASS MODIFY FUNCTION SUCCESSFUL
This example removes all restricted passwords prefixes (including the product defaults) and restore the product defaults at the next REINIT of CA Top Secret:
TSS MODIFY RPW(reset)
