Previous Topic: OPTIONS (z/VM)—Replace Fixes from Prior Product ReleasesNext Topic: Special Characters
PASSCHAR—Password Valid Characters
Valid on z/OS and z/VM.
Use the PASSCHAR control option to add, replace, or remove characters from the password valid character list. When using PASSCHAR:
All entry methods are accepted.
TSS MODIFY PASSCHAR(c,c,c,c,c,c,c,c,c,c,c,c,c,c,c,c)
Default: Binary zeros.
PASSCHAR with NEWPW(SC)
When used in conjunction with control option NEWPW(SC), all passwords must be defined with at least one of the characters in the PASSCHAR list. If NEWPW(SC) is absent, PASSCHAR characters are optional. If no characters are defined in PASSCHAR, NEWPW(SC) has no effect. NEWPW(SC) is a global option for all passwords and facilities. Only use NEWPW(SC) if every application which requires a security password accepts special characters
