Previous Topic: TNGMON—Error MessagesNext Topic: Protection
TSS—Console Prompts
Valid on z/OS.
Use the TSS control option to generate prompts at the operator console for the operator to enter emergency CA Top Secret commands. Commands entered using this method are audit events and are recorded. To avoid flooding the console command output is limited to 50 lines.
To protect secure data from being posted on the system, log command output is routed to the console only. Command input requires the entry of the MSCA previous password at the console. To avoid security exposure, end the session after the needed commands are complete.
All entry methods are accepted.
TSS
The control option is protected by a special prompt for the MSCA's previous password. A record of the event is recorded to provide an audit trail.
