Valid on z/VM.
Use the VMFAC control option logically group VM systems under different facility names.
This control option uses the Parameter File entry method.
VMFAC([sysid=]fac‑name)
The name assigned to the particular VM system as determined by the SYSID macro in the CP installation‑tailored module DMKSYS (VM/SP and SP/HPO) or HCPSYS (VM/XA SP).
If the value for sysid is unknown, contact your installation technical support center. Use the CP command, CP QUERY USERID, displays this value.
Note: If the sysid is omitted, the specified facility is assumed to apply to the VM system on which the server machine has started.
Indicates the facility name.
Default: VMFAC(VM).
