Previous Topic: REFRESH—Reinitialize CA—CAF Modules into CSANext Topic: RESETEOD—Restart After Z Stop
REINIT—Control Blocks and Modules
Valid on z/OS.
Use the REINIT control option to request that CA Top Secret reinitialize its internal control blocks and modules. Use this option only after new maintenance to CA Top Secret has been installed.
This control option uses the Parameter of START command entry method.
REINIT[(K|E|M|1|2|3|S|R)]
REINIT
Reinitializes everything
REINIT(K)
Reloads module TSSKERNL
REINIT(E)
Reloads module TSSEXEC
REINIT(1)
Reloads module TSSMVS01
REINIT(2)
Reloads module TSSMVS02
REINIT(3)
Reloads module TSSMVS03
REINIT(M)
Reloads TSS, TSSIMS, TSSRESPW
REINIT(S)
Reloads module TSSSAF
REINIT(R)
Reloads module TSSRFRVT
Examples: REINIT control option
This example reinitializes all CA Top Secret modules:
S TSS,,,REINIT
This example reinitializes the TSSMVS1 module only:
S TSS,,,REINIT(1)
Note: z/OS systems syntax format requires the insertion of three commas.
