This chapter explains how to invoke and use the monitor interface.
The monitor interface is the same whether it is used from the C3 interface or from the command line interface.
Note: You cannot execute any of the monitor interface commands described in this chapter while connected to a console. To execute these commands, you need to leave the connect interface using the defined escape key and execute the commands from the monitor interface.
This section contains the following topics:
What You Can Do from the Monitor Interface
What the Monitor Interface Looks Like
Starting the Monitor Interface
Getting Help on the Monitor Interface
Connect to the Console of a Serviced System
Unlocking a Console Being Used by Another User
Reading Current Console Log Data
Finding Historical Console Log Data
Reading Previously Archived Log Data
Transmitting a Break Signal on a Console Line
Transmitting a Break Signal with Connection Type of SSH
Displaying Timestamped Console Log Data
Performing a Dialog with a Serviced System
Copyright © 2010 CA.
