Previous Topic: Using the Monitor InterfaceNext Topic: What the Monitor Interface Looks Like
What You Can Do from the Monitor Interface
You can monitor console output from the monitor interface. This interface displays multiple windows of information for monitoring and responding to console activity.
You can do the following tasks from the monitor interface:
You can do these tasks for any system you specify. If you do not specify any, the first system in the configuration database for which you have been granted access will be displayed.
The monitor interface has its own set of commands with which to perform the tasks (see Monitor Interface Commands)
Although you are informed when events occur, if you want to view the context for events on serviced systems, you must do this from the C3 interface. See Chapter 7, “Using Console Manager From the C3 Interface,” for information about how to perform this task.
You can scroll through log data using the keys described in the section, Reading Current Console Log Data.
