To leave the monitor interface, use either the EXIT or the QUIT command from the monitor interface. These commands are synonymous. Alternatively, use the defined exit key from the connect interface. All of these commands access the operating system command line, or close the monitor window if you are using the C3 interface.
Copyright © 2010 CA.
