Previous Topic: Unlocking a Console Being Used by Another UserNext Topic: Manipulating Screen Layout
Reading Current Console Log Data
To read currently selected console log data that has passed from view on your screen, scroll through the data using the keystrokes shown in the following table.
Use this keystroke
To...
Next Screen
Scroll the log data forwards by one log window full of data
Prev Screen
Scroll the log data backwards by one log window full of data
PF1 Up Arrow
Display the message list if one does not already exist, or scroll the message list up by one line if it does
PF1 Down Arrow
Display the message list if one does not already exist, or scroll the message list down by one line if it does
When using a terminal that does not have arrow keys, use the monitor interface commands shown in the following table.
Use this command
To...
UP [lines]1
Move up the log data the specified number of lines for the currently selected system
DOWN [lines]1
Move down the log data the specified number of lines for the currently selected system
TOP
Move to the top of the log data for the currently selected system
BOTTOM
Move to the bottom of the log data for the currently selected system
1If the number of lines is not specified, the log data is scrolled by one log window full of data.
When using multiple log windows, you can switch between them using the keystrokes or commands shown in the following table.
Enter...
To...
NEXT
Make the system in the next log window up the currently selected system
PREVIOUS
Make the system in the next log window down the currently selected system
1The Up and Down arrow keys are used for command line recall
