A dialog is a set of commands contained within a file that is used to interact with serviced systems repetitively.
Use the DIALOG command to perform a dialog with a serviced system or systems. To do this, you must provide a text file containing the dialog commands needed to do your selected task. The following section describes how to create a dialog script.
Copyright © 2010 CA.
