Previous Topic: Transmitting a Break Signal on a Console LineNext Topic: Performing a Dialog with a Serviced System
Displaying Timestamped Console Log Data
To display the time, or to stop displaying the time at which Console Manager logged the console data, use the SET TIMESTAMPS command. This displays timestamps at the left side of the log window for each line of console data. For example, to view the timestamps for data being received from your serviced systems, enter:
Command: SET TIMESTAMPS ON
You cannot set timestamps on data for individual systems.
If you do not use the ON/OFF argument, then the command toggles the display of timestamps.
