Previous Topic: Looking at C3 MessagesNext Topic: Using the Monitor Interface
Using Eventlist Interactively
To start an interactive eventlist from the C3 interface, pull down the Commands menu and choose the Restart Eventlist menu item.
If you want the Eventlist window to appear automatically every time you invoke the C3 interface, you need to set up this option on your C3 interface
To set the option on your C3 interface
  1. Pull down the Options menu and choose the General ... menu item.
  2. This displays the C3 General Options dialog box.
  3. Click the Display Eventlist Window at Startup check button.
  4. Click OK.
See the chapter Using the Eventlist Interface for information about how to use the Eventlist interface.
